The geometry editor was closed abnormally in SpaceClaim
Hi, when I open the SpaceClaim from the WorkBench, I click anywhere on the window and it disappear immediately. After a while, it shows the error: The geometry editor was closed abnormally.The interface is shown in the picture and the below part is my desktop.
When I launch stand-only SpaceClaim, the mouse pointer firstly turns into waiting circular ,but after a while it disappears with nothing happens.
So what should I do to fix it ? There are many posts in the forum,but I find it useless without the same condition.
Thank you for your help in advance
  • HuiLiuHuiLiu Forum Coordinator
    could you try the following steps to clear appdata folder and see if it helps?
    1, Exit ANSYS
    2, from Start > Run
    3, Enter %APPDATA%
    4, An folder explorer window will open
    5, Open the Ansys folder, rename v192 folder to v192_old (or whatever version you are using)
    6, Launch ANSYS again and try refresh the project
    @TaoZhanping
    In the future, please do not create a duplicate post.
