Nonlinear static analysis of cylinder with horizontal load at the top.
While i am implementing Nonlinear static analysis of cylinder with horizontal load at the top the failure happens very early before reaching the maximum stress of concrete or steel please help.
Also please find here my used code:
!********************!  1-preferance  !********************!
/OUTPUT,pushover withOUT openingD7 1.5hd 1 percent,out    !####! TO MAKE OUTOUTS IN SEPARATE FILE AS MASS PARTICIPATION FACTOR
/NOPR
KEYW,PR_SET,1
KEYW,PR_STRUC,1
KEYW,PR_THERM,0
KEYW,PR_FLUID,0
KEYW,PR_ELMAG,0
KEYW,MAGNOD,0
KEYW,MAGEDG,0
KEYW,MAGHFE,0
KEYW,MAGELC,0
KEYW,PR_MULTI,0
KEYW,PR_CFD,0
/GO
!********************!  2-reprocesses !********************!
/PREP7
ET,1,SOLID65    !###! concrete element
ET,2,SOLID65    !###! Grains
!********************!  3-material concrete & grain & reinforcement !********************!
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,1
MPDATA,DENS,1,,2.5E-005
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,EX,1
MPDE,NUXY,1
MPDE,PRXY,1
MPDATA,EX,1,,33346
MPDATA,PRXY,1,,0.2
TBDE,CONC,1,,,
TB,CONC,1,1,9,
TBTEMP,0
TBDATA,,0.3,0.7,3.95,32,0,0
TBDATA,,0,0,0,,,
TBDE,MELA,1,,,
TB,MELA,1,1,18,
TBTEMP,0
TBPT,,0.0002,6.6692
TBPT,,0.0004,11.948
TBPT,,0.0006,16.88
TBPT,,0.0008,21.117
TBPT,,0.001,24.659
TBPT,,0.0012,27.506
TBPT,,0.0014,29.658
TBPT,,0.0016,31.114
TBPT,,0.0018,31.876
TBPT,,0.001919,32
TBPT,,0.0022,31.148
TBPT,,0.0024,30.54
TBPT,,0.0026,29.933
TBPT,,0.0028,29.326
TBPT,,0.003,28.718
TBPT,,0.0032,28.111
TBPT,,0.0034,27.504
TBPT,,0.0035,27.2
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,2
MPDATA,DENS,2,,2.0918E-009
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,EX,2
MPDE,NUXY,2
MPDE,PRXY,2
MPDATA,EX,2,,1.361E+005
MPDATA,PRXY,2,,0.36
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,DENS,3
MPDATA,DENS,3,,7.85E-005
MPTEMP,,,,,,,,
MPTEMP,1,0
MPDE,EX,3
MPDE,NUXY,3
MPDE,PRXY,3
MPDATA,EX,3,,2.1E+005
MPDATA,PRXY,3,,0.3
TBDE,BISO,3,,,
TB,BISO,3,1,2,
TBTEMP,0
TBDATA,,360,5000,,,,
!********************!  4-REAL CONSTANT FOR RFT  !********************!
!********************!  5-define Volume  !********************!
CYL4, , ,1500, ,1425, ,6000
CYL4, , ,1425, ,1350, ,6000
LPLOT
!********************!  6-GLUE!********************!
FLST,2,2,6,ORDE,2
FITEM,2,1
FITEM,2,-2
VGLUE,P51X
FLST,2,10,5,ORDE,4
FITEM,2,1
FITEM,2,-6
FITEM,2,11
FITEM,2,-14
AGLUE,P51X
FLST,2,30,4,ORDE,8
FITEM,2,1
FITEM,2,-20
FITEM,2,25
FITEM,2,-28
FITEM,2,33
FITEM,2,-36
FITEM,2,39
FITEM,2,-40
LGLUE,P51X
!********************!  6-Meshing!********************!
!* 1- top & bottom
FLST,5,24,4,ORDE,6
FITEM,5,1
FITEM,5,-16
FITEM,5,25
FITEM,5,-28
FITEM,5,33
FITEM,5,-36
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,12, , , , ,0
!* 2-wall
FLST,5,6,4,ORDE,4
FITEM,5,17
FITEM,5,-20
FITEM,5,39
FITEM,5,-40
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
LESIZE,_Y1, , ,30, , , , ,0
!*VSWEEP
FLST,5,2,6,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CMSEL,S,_Y
CMSEL,S,_Y1
VATT,    1, ,  1,    0
CMSEL,S,_Y
CMDELE,_Y
CMDELE,_Y1
FLST,5,2,6,ORDE,2
FITEM,5,1
FITEM,5,3
CM,_Y,VOLU
VSEL, , , ,P51X
CM,_Y1,VOLU
CHKMSH,'VOLU'
CMSEL,S,_Y
VSWEEP,_Y1
CMDELE,_Y
CMDELE,_Y1
CMDELE,_Y2
ET,4,LINK180
R,2,1500, ,0
!********************!  5-create keypoints  !********************!
FLST,3,4464,1,ORDE,2
FITEM,3,1
FITEM,3,-4464
KNODE,0,P51X
! *******! 6- reinforcement
LSTR,73,   3728
LSTR,74,   3729
LSTR,75,   3730
LSTR,76,   3731
LSTR,77,   3732
LSTR,78,   3733
LSTR,79,   3734
LSTR,80,   3735
LSTR,81,   3736
LSTR,82,   3737
LSTR,83,   3738
LSTR,84,   3716
LSTR,85,   3717
LSTR,86,   3718
LSTR,87,   3719
LSTR,88,   3720
LSTR,89,   3721
LSTR,90,   3722
LSTR,91,   3723
LSTR,92,   3724
LSTR,93,   3725
LSTR,94,   3727
LSTR,95,   3726
LSTR,96,   4478
LSTR,97,   4479
LSTR,98,   4480
LSTR,99,   4481
LSTR,100,   4482
LSTR,101,   4483
LSTR,102,   4484
LSTR,103,   4485
LSTR,104,   4486
LSTR,105,   4487
LSTR,106,   3769
LSTR,107,   4488
LSTR,108,   3739
LSTR,109,   4466
LSTR,110,   4467
LSTR,111,   4468
LSTR,112,   4469
LSTR,113,   4470
LSTR,114,   4471
LSTR,115,   4472
LSTR,116,   4473
LSTR,117,   4474
LSTR,118,   4475
LSTR,119,   4477
LSTR,120,   4476
! *******! 8-Mesh reinforcement section
FLST,5,48,4,ORDE,8
FITEM,5,21
FITEM,5,-24
FITEM,5,29
FITEM,5,-32
FITEM,5,37
FITEM,5,-38
FITEM,5,41
FITEM,5,-78
CM,_Y,LINE
LSEL, , , ,P51X
CM,_Y1,LINE
CMSEL,,_Y
TYPE,  4
MAT,    3
REAL,    2
ESYS,    0
SECNUM,
FLST,2,48,4,ORDE,8
FITEM,2,21
FITEM,2,-24
FITEM,2,29
FITEM,2,-32
FITEM,2,37
FITEM,2,-38
FITEM,2,41
FITEM,2,-78
LMESH,P51X
! *******! 7- HZ reinforcement
FLST,3,4,4,ORDE,2
FITEM,3,5
FITEM,3,-8
LGEN,30,P51X, , , , ,200, ,0
TYPE,  4
MAT,    3
REAL,    2
ESYS,    0
SECNUM,
FLST,2,120,4,ORDE,4
FITEM,2,5
FITEM,2,-8
FITEM,2,79
FITEM,2,-194
LMESH,P51X
TYPE,  4
MAT,    3
REAL,    2
ESYS,    0
SECNUM,
FLST,2,4,4,ORDE,2
FITEM,2,13
FITEM,2,-16
LMESH,P51X
ALLSEL,ALL
/REPLOT
EPLOT
NUMMRG,NODE, , , ,LOW
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
FLST,2,24,1,ORDE,2
FITEM,2,812
FITEM,2,-835
/GO
F,P51X,FX,100000
FLST,2,1,1,ORDE,1
FITEM,2,865
/GO
F,P51X,FX,100000
FLST,2,23,1,ORDE,2
FITEM,2,1562
FITEM,2,-1584
/GO
F,P51X,FX,100000
FLST,2,144,1,ORDE,2
FITEM,2,1
FITEM,2,-144
/GO
D,P51X, , , , , ,ALL, , , , ,
/SOL
ANTYPE,0
DELTIM,250,150,2500
OUTRES,ERASE
OUTRES,ALL,ALL
RESCONTRL,DEFINE,ALL,ALL,0
TIME,4800000
CNVTOL,F, ,0.05,2, ,
ALLSEL,ALL
EPLOT
  • jjdoylejjdoyle PittsburghMember
    You have a negative tangent stiffness slope for material #1 as indicated by the following error.
    Also, you are applying a force based load.
    This looks like a simple enough model.
    After you fix the material input, try replacing the force with a displacement for stability.
