Material Designer : Not able to solve RVE.
premikapremika Member
edited September 24 in Structures
I'm trying to create a RVE model in the Material Designer. I used both pre-deifned and user-defined geometry. With the default values I created the model and when I try to solve, it freezes. I'm using 2020 R1 version. Please help.
Premika
  • KaiKai Forum Coordinator
    Hi @premika , it is likely material designer is just working on it. Internally, material designer run 6 static structural analysis (tension x/y/z, shear x/y/z). Creating the input files and solve it could take some time depending on your hardware. Can you try to reduce mesh and give it a try again?
