How to delete failed design points from DOE?
If for example you want to delete DPs that are created automatically or if some DPs failed to solve in the table of DOE, you can change the DOE Type to "Custom+Sampling" and DOE table becomes editable and you can delete or add DPs manually.
Thanks @djandric for this tip.
