Installation errors
dzunghtddzunghtd Member
edited September 25 in Ansys Free Student Software
I am trying to install the Ansys Electronics Suites 2020R2 win 64bits on Window Bootcamp which is parallel OS with MAC OS.
The system information are:
  1. Intel Core i7-9750H CPU
  2. 16 GB RAM
  3. 64-bit OS
  4. Storage: 100 GB SSD partition from MAC's storage (24GB free remaining).
Firstly, I tried to run aurorun file. There is error prompted like below.
Secondly, (after failing in running as administrator the autorun aforementioned) I tried to manually install manually by installing the Prerequisites folder, and AnsysEM as well. In the Prerequisites installation step, Visual C++ 2010 SP1 Redistributables and Visual C++ 2012 SP4 Redistributables have error "Extraction Failed: The system cannot find the path specified" like below.
I ignored these prerequisites errors, and keep installing the remaining parts. After the AnsysEM installation step, there is error found as pictures below:
Would you help me to figure out these problem?
Hope to hear from you soon.
Thank you so much.
BRs,
Ha
    Can you try unzipping/extracting the package again ?
  • dzunghtddzunghtd Member
    edited September 25
    Thanks for your reply.
    I also tried to uninstall, re-download, re-extract-all, and re-install several times.
    Hope you can help me figure it out?
    Open CMD prompt and enter the following command
    set
    then post the output of it here
  • Hi,
    Thank for your reply. Please refer to the content below as your request.
    C:\Users\HàTrungDũng>set
    ALLUSERSPROFILE=C:\ProgramData
    ANSYSEM_ROOT202=C:\Program Files\AnsysEM\AnsysEM20.2\Win64
    ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1
    APPDATA=C:\Users\HàTrungDũng\AppData\Roaming
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=DESKTOP-MAJ0UDK
    ComSpec=C:\Windows\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    HOMEDRIVE=C:
    HOMEPATH=\Users\HàTrungDũng
    LOCALAPPDATA=C:\Users\HàTrungDũng\AppData\Local
    LOGONSERVER=\\DESKTOP-MAJ0UDK
    MOZ_PLUGIN_PATH=C:\Program Files (x86)\Foxit Software\Foxit Reader\plugins\
    MSMPI_BENCHMARKS=C:\Program Files\Microsoft MPI\Benchmarks\
    MSMPI_BIN=C:\Program Files\Microsoft MPI\Bin\
    NUMBER_OF_PROCESSORS=12
    OneDrive=C:\Users\HàTrungDũng\OneDrive
    OS=Windows_NT
    Path=C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Users\HàTrungDũng\AppData\Local\Microsoft\WindowsApps;
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 158 Stepping 10, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=9e0a
    ProgramData=C:\ProgramData
    PROMPT=$P$G
    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
    PUBLIC=C:\Users\Public
    SESSIONNAME=Console
    SIMPLORER_HOME=C:\Program Files\AnsysEM\AnsysEM20.2\Win64
    SIWAVE_INSTALL_DIR=C:\Program Files\AnsysEM\AnsysEM20.2\Win64
    SystemDrive=C:
    SystemRoot=C:\Windows
    TEMP=C:\Users\HTRUNG~1\AppData\Local\Temp
    TMP=C:\Users\HTRUNG~1\AppData\Local\Temp
    USERDOMAIN=AzureAD
    USERDOMAIN_ROAMINGPROFILE=AzureAD
    USERNAME=HàTrungDũng
    USERPROFILE=C:\Users\HàTrungDũng
    windir=C:\Windows
  • Hi,
    I tried with another account with admin but there is error like below.
    Please refer to the result of "set" command in cmd window below.
    C:\Users\dzung>set
    APPDATA=C:\Users\dzung\AppData\Roaming
    FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
    FPS_BROWSER_USER_PROFILE_STRING=Default
    HOMEDRIVE=C:
    HOMEPATH=\Users\dzung
    LOCALAPPDATA=C:\Users\dzung\AppData\Local
    OneDrive=C:\Users\dzung\OneDrive
    OneDriveConsumer=C:\Users\dzung\OneDrive
    OS=Windows_NT
    Path=C:\Program Files\Microsoft MPI\Bin\;C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\iCLS\;C:\Program Files\Intel\Intel(R) Management Engine Components\iCLS\;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Users\dzung\AppData\Local\Microsoft\WindowsApps
    PROCESSOR_LEVEL=6
    PROMPT=$P$G
    PSModulePath=%ProgramFiles%\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
    SESSIONNAME=Console
    SystemDrive=C:
    TEMP=C:\Users\dzung\AppData\Local\Temp
    TMP=C:\Users\dzung\AppData\Local\Temp
    USERDOMAIN_ROAMINGPROFILE=DESKTOP-MAJ0UDK
    USERPROFILE=C:\Users\dzung
    windir=C:\Windows
    C:\Users\dzung>
  • Hello,
    Thank you. Now it worked. Thank you so much for your help.
    BRs,
    Ha
    That's great ! Glad it works for you !
    Win
  • Hi
    I am trying to install ANSYS Workbench 2020 R2. I have unzipped the folder, but when I try to install the setup it gives a critical error (not responding) . Please Suggest the needful. Tried to do it several times but everytime same issue.
    Vaishali
