Mesh problem. Help please
Dear collegues,
I am doing my pre-doctoral project working simulating a kayak.
The problem I got is that, when I try to mesh, I got this:
The model looks good, but the problem is when I mesh. Here is my model:
What could I do?
Thank you very much !!!
rkumbhar PuneForum Coordinator
Hi @manmorcan ,
Here are some suggestion.
- Use refined mesh sizing.
- Use curvature size function
- turn on defeaturing and use defeature size bigger than thin faces so that it can ignore the sliver faces.
- Insert Virtual topology object in the tree. Select the body, right click and generate virtual cells. It may simplify face representation if there are problematic faces.
Hi @manmorcan ,
@manmorcan
Did you manage to close the surface model and get a solid body for the kayak before you created the Enclosure for the Fluid Domains?
Did you split the Fluid Domains at the waterline? That plane could also split the kayak.
Then you can use Shared Topology to put the kayak pieces back together.
Dear Rkumbhar,
it was due to the solid.
I fixed it in a design program and then introduced it again in Ansys and It worked!
Thanks!!
