Obtain node displacement for each mode in modal analysis APDL commands
Hi all!
I'm trying to automatize a modal analysis, so I want to write displacements in some selected nodes in a .txt file, so I wrote this code:
*cfopen, node_displacement1,txt     !Create a txt file
*do,i,1,51,1      ! Loop over each node
  nsel,s,node,,i,i        ! Select the corresponding node
  *get,uy, node, i,U,Y      ! Get the y-displacement of node i
  *get,uz, node, i,U,Z      ! Get the z-displacement of node i
  *vwrite, i,uy,uz        ! Write out these values
  (4F16.5)            ! Define the format
*enddo
*CFCLOS
But I have a problem.
This code works well in a static structural analysis, but it doesn't work in a modal analysis.
So this is my question, how could I obtain the same results for each mode in the modal analysis?
Thanks for all.
