HFSS Scripting Error ('GetDataExpressions()') method is not working
I am facing errors when using some of the methods provided in "Reporter Editor Script Commands" Module. I have attached the script that I tried to execute which causes the execution errors.
oProject = oDesktop.GetActiveProject()
oDesign = oProject.GetActiveDesign()
oDesign = oProject.SetActiveDesign(oDesign.GetName())
oModule = oDesign.GetModule('ReportSetup')
expressions = oModule.GetDataExpressions()
"MissingMemberException: 'IDispatch' object has no attribute 'GetDataExpressions'"
The same issue is happening with most of the methods provided in this module. I have listed a few of them as follows:
GetSweepValues, GetDataUnits, GetDesignVariableNames, GetSolutionDataPerVariation
If anyone how to use these methods properly in order to get the plot data without exporting it into a file, please respond to this question.
  • AndyJPAndyJP Member
    actually, I would love to see a solution myself. setting design variables is described, and can be generated using script wizzard. But building object references for reading report values is not covered in manuals.
  • rtkrtk Pune, IndiaForum Coordinator
    Hello Mahesh-
    The above mentioned error is because the Module 'ReportSetup' cannot handle these set of attributes/functionalities.
    As per the script that you have written, it should return the values.
    Let us work on this with some expertise team and will get back to you!
    Beat Regards,
