Modelising a composite material (not in layers)
I'm looking to modelise a specific composite materials ( it is composed by two materials in the microstrucure : 40Ti3AlC2 and 60Al, I joint an image (SEM) :
I dont know how to do that, I know to modelise only in layers
Thanks you
You can probably use Material Designer. Have a look at the relevant section in Ansys Help:
You might need to generate a custom geometry for you RVE, given that it looks like an irregular, non-periodic, random structure.
Hope this helps,
Sai
I dont have access to your link, can you copy me what it says
Thanks you for your answer
