LS-DYNA on not memory issue
I ran a simulation on cluster and the total simulation time is 3s. Finally it shows that:
Max. Memory reqd for implicit sol: max used        0
 Max. Memory reqd for implicit sol: incore         0
 Max. Memory reqd for implicit sol: oocore         0
 Memory required to complete solution (memory=  1290K memory2=  154K)
     Minimum  143K on processor   4
     Maximum  154K on processor   1
     Average  148K
 Additional dynamically allocated memory
     Minimum  2125K on processor   0
     Maximum  2317K on processor   1
     Average  2261K
 Total allocated memory
     Minimum  2278K on processor   0
     Maximum  2470K on processor   1
     Average  2409K
Since the material is purely hyperelasticity, we can condense the time. When I condensed the same simulation to 0.01s, the simulation runs good. there is no problem.
Since I need to run it using 3s rather than 0.01 in the end, Could you give me help?
The attachment is my message file by my cluster.
Thank you!
Teng Long
  • mjimji Forum Coordinator
    3 sec is too long for explicit solver, you might want to use mass scaling or velocity scaling.
  • Since I need will add viscoelasticity effect, so with strain rate = 10%/s with strain = 30%, so I need to have a test on 3s for the hyperelasticity material first to estimate the total time I need to use and then add the viscoelasticity.
    Do you mean LS DYNA explicit solver run for 3s?
    Thank you!
  • I don't agree with that explicit dynamics solver can not ran for 3s, so I would appreciate that a LS DYNA, ANSYS technique engineer can answer my question.
    Thank you!
