Results in Fluid Flow (Fluent) "Application failed to connect" in Ansys 2020 R2
KonstantinosMKonstantinosM Member
edited October 2 in Ansys Products
Hello Ansys family,
So the problem I have is that whenever I press the results icon in fluid flow the above message pops up. I read couple of things in the forum, like:
-installing all of the prereq files again,
-opened the CFX from start menu (success)
But the problem is not quite fixed. I don't know how to import my model into the CFX app manually.
I had the 2020 R1 version initially with the same problem, now I uninstalled it and installed the R2 version all over again and the problem is still there.
Please help,
Konstantinos
  • Hello,
    I'm moving this post to the 'Installation' category for better alignment.
    Thanks.
    Launch Product & CAD Configurations tool with 'run as administrator' -> Configure Products and CADs , then configure all products. Make sure CFD Post is in this list as well
    If that doesn't work, post the output of 'set' command (without quotes) from CMD Prompt
  • Dear Mr. @tsiriaks ,
    Thank you for your reply.
    So the following thing shows up,
    And as I press Next, this appears:
    ___________________________________________________________________________________________________________________
    Reading the installation media contents - please wait.
    Extraction: C:\Program Files\ANSYS Inc\ANSYS Student\v202\installer\instcore\tcl\COMMON.TGZ ...
    Extraction: C:\Program Files\ANSYS Inc\ANSYS Student\v202\installer\instcore\tcl\WINX64.TGZ ...
    Creating Start menu items for ANSYS client licensing ...
    Configuration Complete. Please review the above information.
    What should I do? Thank you in advance
    You are supposed to see list of products in that page. This indicates some issue with installation.
    Do you have install.err file under C:\Program Files\ANSYS Inc\ANSYS Student\ ? If so, post the content of it here
    Also, post the output of 'set' command (without quotes) from CMD Prompt
  • Dear @tsiriaks ,
    No, there isn't any install.err file in the directory you asked.
    The following is the output of set command:
    ALLUSERSPROFILE=C:\ProgramData
    ANSYS202_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v202\ANSYS
    ANSYS_SYSDIR=winx64
    ANS_OLD_ATTACH=1
    APPDATA=C:\Users\kosta\AppData\Roaming
    AWP_LOCALE202=en-us
    AWP_ROOT202=C:\Program Files\ANSYS Inc\ANSYS Student\v202
    CADOE_LIBDIR202=C:\Program Files\ANSYS Inc\ANSYS Student\v202\CommonFiles\Language\en-us
    CommonProgramFiles=C:\Program Files\Common Files
    CommonProgramFiles(x86)=C:\Program Files (x86)\Common Files
    CommonProgramW6432=C:\Program Files\Common Files
    COMPUTERNAME=KONSTANTINOS
    ComSpec=C:\Windows\system32\cmd.exe
    DriverData=C:\Windows\System32\Drivers\DriverData
    FPS_BROWSER_APP_PROFILE_STRING=Internet Explorer
    FPS_BROWSER_USER_PROFILE_STRING=Default
    HOMEDRIVE=C:
    HOMEPATH=\Users\kosta
    LOCALAPPDATA=C:\Users\kosta\AppData\Local
    LOGONSERVER=\\KONSTANTINOS
    LSTC_LICENSE=ANSYS
    NUMBER_OF_PROCESSORS=8
    OneDrive=C:\Users\kosta\OneDrive
    OneDriveConsumer=C:\Users\kosta\OneDrive
    OS=Windows_NT
    Path=C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\System32\OpenSSH\;C:\Program Files\NVIDIA Corporation\NVIDIA NvDLISR;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Users\kosta\AppData\Local\Microsoft\WindowsApps;
    PROCESSOR_ARCHITECTURE=AMD64
    PROCESSOR_IDENTIFIER=Intel64 Family 6 Model 126 Stepping 5, GenuineIntel
    PROCESSOR_LEVEL=6
    PROCESSOR_REVISION=7e05
    ProgramData=C:\ProgramData
    PROMPT=$P$G
    PSModulePath=C:\Program Files\WindowsPowerShell\Modules;C:\Windows\system32\WindowsPowerShell\v1.0\Modules
    PUBLIC=C:\Users\Public
    P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v202\AISOL\CADIntegration\Parasolid\PSchema
    SESSIONNAME=Console
    SystemDrive=C:
    SystemRoot=C:\Windows
    TEMP=C:\Users\kosta\AppData\Local\Temp
    TMP=C:\Users\kosta\AppData\Local\Temp
    USERDOMAIN=KONSTANTINOS
    USERDOMAIN_ROAMINGPROFILE=KONSTANTINOS
    USERNAME=konstantinos
    USERPROFILE=C:\Users\kosta
    windir=C:\Windows
  • @tsiriaks I downloaded 2019 R3 and tried again but the same thing happened unfortunately.
    C:\Users\kosta>set
    ANSYS195_DIR=C:\Program Files\ANSYS Inc\ANSYS Student\v195\ANSYS
    ANSYS_SYSDIR=winx64
    ANS_OLD_ATTACH=1
    AWP_LOCALE195=en-us
    AWP_ROOT195=C:\Program Files\ANSYS Inc\ANSYS Student\v195
    CADOE_LIBDIR195=C:\Program Files\ANSYS Inc\ANSYS Student\v195\CommonFiles\Language\en-us
    HOMEDRIVE=C:
    LSTC_LICENSE=ANSYS
    OS=Windows_NT
    PROCESSOR_LEVEL=6
    PROMPT=$P$G
    P_SCHEMA=C:\Program Files\ANSYS Inc\ANSYS Student\v195\AISOL\CADIntegration\Parasolid\PSchema
    SESSIONNAME=Console
    SystemDrive=C:
    windir=C:\Windows
    that's what appeared in this version.
    What is the file name of the installation package that you used ?
    Please post the content of install.log from C:\Program Files\ANSYS Inc\ANSYS Student\  , you can just show the part that's for version 2020 R2
    Do you have
    C:\Program Files\ANSYS Inc\ANSYS Student\v202\commonfiles\configs\winx64\config\AnsConfigCFDPost.exe
    If so, run this with 'run as administrator'
    If not, do you have other files in this directory ?
  • @tsiriaks
    File name of the installation package I used: ACADEMICSTUDENT_2019R3_WINX64
    Content of install.log (I installed 2020R1, then 2020R2 and lastly 2019R3):
    Content has too many characters to post as a comment but it ends like that:
    Adding write permissions for Users and Administrators group ...
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigCFX.exe
    Configuring ANSYS Viewer ...
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigSpaceClaim.exe
    Configuring ACP ...
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigACP.exe
    Configuring Help ...
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigHelp.exe
    ANSYS Internet Doc has been configured.
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigCHEMKIN.exe
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigFORTE.exe
    Running C:\Program Files\ANSYS Inc\ANSYS Student\v195\commonfiles\configs\winx64\config\AnsConfigFENSAP.exe
    Running "C:\Program Files\ANSYS Inc\ANSYS Student\v195\aisol\..\commonfiles\CAD\bin\winx64\Ans.CadInt.CADConfigurationUtility.exe"
    Log files is C:\Program Files\ANSYS Inc\ANSYS Student\v195\CADConfigLogs\Latest\CADConfigurationMgr.log
    MessageLogger.logFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v195\CADConfigLogs\Latest\CADConfigurationMgr.log
    ErrorLogger.errorFilePath is C:\Program Files\ANSYS Inc\ANSYS Student\v195\CADConfigLogs\CADConfigurationMgr.err
    Prerequisites ..... Configure Success
    SCDM Workbench PlugIn ..... Configure Success
    Successfully created file associations.
    Installation Complete: Τετ Οκτ 7 14:08:25 2020
    I have these in the location you asked:
  • @tsiriaks @Rob , Is there any chance that you know what should I do? Thank you in advance
    @KonstantinosM It appears you installed the 2019R3 version, which has an expired license. Can you try downloading and installing the 2020R2 version from here?
    https://www.ansys.com/academic/free-student-products
  • Dear @mmadore ,
    Yes you are right, I have installed 2019R3 version as a final resort, because I previously downloaded 2020R1 and 2020R2, but the same error appears. Regarding the license, I followed the steps in the installation guide ( https://forum.ansys.com/discussion/19805/how-to-renew-ansys-student-product-license#latest ).
    Can you provide any assistance?
    Thank you in advance,
    Konstantinos
    @KonstantinosM Can you open up a blank, stand-alone CFD-Post ?
    Is there any issue using other products in the Workbench ?
  • KonstantinosMKonstantinosM Member
    edited October 19
    @mmadore, Yes Cfd-post opens stand-alone with no problem at all.
    Actually, in a structural model I created everything was ok, but in a cfx fluid flow simulation I have the same error in the setup application in contrast to a fluent fluid flow simulation when the error appeared in the results section.
    Thank you a lot and waiting for your help,
    Konstantinos
