How to select one CPU from dual CPU to run on?
  • danielshawdanielshaw Forum Coordinator
    The combination/distribution of cores to be used cannot be manually controlled by the user. It is automatically controlled at the OS level.
    For example, a dual CPU computer with 12 cores per CPU will have 24 cores total. You can specify the solution to use 12 cores, but you cannot specify it to use 12 cores from a specific CPU.  It will select the appropriate 12 cores to use from either CPU.
