How to get solution solved faster in 2D Explicit Dynamics
FernandoTorresFernandoTorres Madrid, SpainMember
Hi, currently I'm solving a 2d explicit dynamics problem with approx. 9k nodes and 9k elements with 1.6058e-8m mesh size on a server (32Gb Ram and 2 cores). Estimated Solution time is 1236 hrs (ofcrs not feasible).
Any way to solve it faster and get accurate results. Thanks.
Best Answers
  • FernandoTorresFernandoTorres Madrid, SpainMember
    I'll try to go "transient"...
    But what if I increase cores, and with a "reasonable enough mesh", will this solve the problem little faster?
    i.e. does solution time of a 2d explicit analysis depends on ram, cores or both (I'm asking for hardware here not cfl equation parameters)
    Thanks a lot.
  • @FernandoTorres
    For any solver, if you go from 2 cores to 16 cores, you will reduce the solution time by less than a factor of 8.
    If you double the computer clock speed from 2 GHz to 4 GHz, you will reduced the solution time by a factor of 2.
    Implicit solvers need more RAM, but if the problem size fit in the existing RAM, increasing the amount of RAM will have no effect.
    The maximum time step size is set by the minimum element length for Explicit, while for Implicit solvers, it is set by the highest natural frequency of interest in the structure. The ratio of the maximum time step of Implicit/Explicit for your nano-scale elements might be a factor on the order of 1000.
    Thanks Sir @peteroznewman , shifted the model from explicit to transient but the tool is getting into the workpiece without cutting anything i.e. tool just moves inside workpiece without cutting the material. Tried to setup the contacts manually but it didn't work. What could be the issue?
    Thanks.
    Great Article Sir @peteroznewman , but I have issues in material removal (chip formation). When I run the same experiment in explicit dynamics, cutting is shown with proper chip formation, BUT ONCE I shift the model to TRANSIENT structural, there is no cutting like shown below (tool moves freely into the material without cutting). I know this is a childish question but it is what it is.
    thanks for your help.
    Thanks Sir @peteroznewman , I'll check that out in more detail. "Parallel processing is only available for 3d models" says the AUTODYN Solver for my 2d explicit dynamics problem. I know you have stated about the hardware on top of this page but I wonder if that is still valid for AUTODYN 2D Explicit Analysis.
    Thanks.
