Installation error
I'm trying to instal ANSYS STUDENT 2019 R3. But I have the same problem, several times.
Please, anyone who can give ay advice. I would appreciate it.
Date verification complete...No conflicts found.
The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
This may take a while ...
Successfully copied prerequisites from media.
You're missing required prerequisites.
Installing MS VC++ 2013 Redistributable x86
Installing MS VC++ 2017 Redistributable x86
Installing MS VC++ 2017 Redistributable x64
There was a problem installing the following prerequisites:
Would you like to re-try?
If the installation of the prerequisites fails after multiple attempts, please attempt to install the prerequisites yourself, or contact your system administrator.
    From the ANSYS Student installation package, you can go into 'prerequisites' folder, then manually install these MSVC++
    If there is any issue installing these, it will tell the reason.
