Midsurfacing Problem
Hello.
I’m trying to make a structural analysis with shell model. Solid model shown in the below.
I get the shell model from solid model by midsurfacing. After the midsurfacing operation, the surfaces added a new part. So far, there is no problem.
But when it comes to defining contact between surfaces and making mesh, problem arises as you can see in the picture below.
I made some changes to the 'Offset Type' to fix this problem, but the surfaces still overlap.
 I would really appreciate if you can help. Thanks…
