How to save results every nth load step?
I have multiple load steps, and the result file created is very big. Can I save results at specific intervals if I don't need results at each timestep?
  • cxquancxquan Berkeley, CAForum Coordinator
    One may use following command to save results every nth step: (In Mechanical Insert a command object under Transient, set the Step Selection Mode to All with these commands):
    save=3            ! save every third solution (n=3 here)
    *get,a1,active,,solu,ncmls  ! gets number of completed load steps
    b1=mod(a1,save)       ! remainder so 0 means it is a multiple of save
    *if,b1,eq,0,then outres,erase
    outres,all,all
    *else
    outres,erase
    outres,all,none
    *endif
