Mechanical Results Tracker coordinate system
jjdoylejjdoyle PittsburghMember
Mechanical Results Tracker is using the 'NLHIST' command under the hood. All results are tracked in the Solution Coordinate System (that is, nodal results are in the nodal coordinate system and element results are in the element coordinate system). Refer to the MAPDL Command Documentation 'NLHIST' command for more details about capabilities, assumptions and limitations.
