Current leak to the air
Hello, I am currently simulating a transformer with a scatter path. After changing the size of this leakage path the error "Current leak to the air" occurs. Can you tell me the reason for this or how I can solve it?
For the sake of simplicity, the two closer outer legs are hidden. The distance between the scattering path and the outer leg is 0.75mm
Thank you for your time
Michael
