Fluent journal command
Does anyone know the journal command for exporting solution data in ascii formatFLUENT say after every 50 time steps for selected scalar variables at all node points? I need the journal command to run in a cluster computer. I know how to do this through GUI but I need the journal command to put in the journal file. Any help would be appreciated
Use Quick Search to search required commands.
Please see help manual for more details about these commands.
Keyur
okay i was able to use this command, however only 1 file was saved. i need to save files like every 100 iterations and the command gave me only 1 solution file in ascii format.
do you suggest anything so that i can save multiple no of files?
Please check
/solve/execute-commands>
Keyur
