Error message
in Electronics
Hi
Anybody know how to solve this errors.
Can not access or create directory C:/Program Files/AnsysEM/AnsysEM19.2/Win64/UdmDefFiles/
Surface Mesh Generation Failed
Hi
Which product are you using? Also, can you please share when you get this error message (when you launch the product or what you are running a particular model)?
I am using HFSS. I got this error when running a model. In the model, I have defined a sheet as layered impedance and has assigned the desired material on it.
It does not look like a model-related problem.
This may be a user-access-rights related problem. Are you running HFSS as admin/superuser, or as a restricted user? In the latter case, ask your admin to provide full access rights to the mentioned directory.
Hello- This error can cause due to different aspects of the simulation. Sometimes a convergence issue within the model also ends up in such errors.
Please attach an image of the profile data (Results>>SoultionData>>Profile>>Export) so that we can guide you accordingly.
Best Regards,
