time varying thermal conductivity for transient thermal analysis
Is there a way to define time varying quantities of thermal conductivity for a transient thermal?
I'm trying to solve a transient thermal problem, where in I knew the time variation of conductivities a priori. Basically, i was doing a multiple solve, and a each step i was using the MPDELE, and then try to redefine the material at a given time using MPDATA.
The solver triggered a warning that ' changing the material property during solution is a 'non-standard way'. Is it a correct way to define time varying quantities of a thermal- material property?
May i know if there any other standard way to define it.
Below is the script i tried to come up with
FINISH
/CLEAR,NOSTART
/PREP7
LENGTH=2e-03 ! 2*LENGTH, mm
HEIGHT=LENGTH/100 ! HEIGHT, mm
THICK=HEIGHT
esize=HEIGHT
area=HEIGHT*THICK
kxx_1 = 5.000000000E-03 ! VALUE AT initial time, t=0
cx_1 = 4.039360000E-02 ! VALUE AT initial time, t=0
t1= 358.000 ! inital temperature
mptemp,1,t1
mpdata,KXX,1,1,kxx_1
mpdata,C,1,1,cx_1
ET,1,LINK33
R,1,area ! AREA
k,1,-0.5*LENGTH
k,2, 0.0
k,3, 0.5*LENGTH
l,1,2
l,2,3
lglue,1,2
lesize,all,esize
type,1
real,1
mat,1
lmesh,all
esel,s,type,,1
nsle,r
IC,all,temp,1
allsel,all,all
d,node(-0.5*LENGTH,0,0),temp,0
d,node(0.5*LENGTH,0,0),temp,0
FINISH
/SOLU,
ANTYPE,TRANS
KBC,0
nleng=40
deltime=2
*dim,dxx_1,array,nleng,1
*dim,ccstinter_1,array,nleng,1
*do,tt,1,40
currtime=deltime*tt
curr_temp=(273+85)+2*deltime*(tt)
dxx_1(tt,1)=D0_1*exp((-ED_1)/(R*curr_temp))
ccstinter_1(tt,1)=RH*S0_1*P0_1*exp((ES_1-EVP_1)/(R*curr_temp))
mptemp,1,0
mpdele,kxx,1
mpdata,kxx,1,,dxx_1(tt,1)
mpdele,c,1
mpdata,c,1,,ccstinter_1(tt,1)
allsel,all,all
OUTRES,ALL,ALL
TIME,currtime
NSUBS,1,1,1
solve
*enddo
FINISH
Hi @vkr535 , you are getting warning because it is not ideal way but if the results are okay, you should go with this option. There is one more way you can try using MPCHG command in solution processor for each load step.
