Ansys 19.2 EM Uninstaller Wont Run
Trying to run the uninstaller (have tried via script and manually) and get a message that it detects that the uninstaller is already running. I have restarted with the same result and also tried several computers.
Anyone else run into this?
    @rmadams How did you try to uninstall? Did you use Windows -> Programs and Features, or did you try running the files from C:\Program Files\AnsysEM\Uninstall ?
  • I am running from C:\Program Files\AnsysEM\Uninstall. The goal is to send a script to uninstall remotely, but I have tried running the uninstaller manually from this folder as well.
    Can you try:
    "C:\Program Files\AnsysEM\AnsysEM19.2\Win64\Uninstall\setup.exe" /runfromtemp /z suppressconfirmation /removeonly
  • Hi,
    That is what we are using - we have tried with and without the /runfromtemp.  Still getting the message that it detects that the uninstaller is already running.  This happens after rebooting as well (and we just run the uninstaller by hand).
    Thanks!
  • rjkosarirjkosari Forum Coordinator
    If you look in Windows task manager -> Details tab. Do you see a "setup.exe" process running?
    In Windows Add/Remove Programs, is "ANSYS Electronics Suite 19.2" listed?
    Please confirm, the exact message being displayed.
