Anisotropic / Orthotropic
in Structures
I have a query regarding Validation of anisotropic / orthotropic material. Can I use for that Euler or Timoshenko beam Theory? I want to simulate one sided simply supported beam case to understand material properties. And is it true, if I have E-Modul in X double than E-Modul in Y, then the deformation in X is also double than Y. Thank you for your reply.
@Tejas8 , Ansys beam188 element is based on Timoshenko beam theory.
