ANSYS LICENSE MANAGER ERROR
I am trying to open geometry for a Fluid Flow (Fluent) and I get this error. I can't seem to find anything like this error. What should I do?
    Which ANSYS Student product did you install? Can you post the contents of the referenced license file?
  • This is what is in the file they are referring to in the error. I downloaded ANSYS student edition for my college course.
    Did you also have the full versions of ANSYS installed by any chance, or only ANSYS Student? SpaceClaim should run under the aa_s_disc license.
    Also, can you please send the FULL output of this command in a Windows command prompt?
    set ANS
    Thank you,
    Matt
  • I did have ANSYS before but I think I uninstalled it and I cannot find it on my computer now so I guess its gone. I'm sorry but I don't know how to show the output of this command. Is there something that can show me how to do that?
    Go to your Windows Start menu and type "cmd" without the quotes, and open the Command Prompt. Then enter "set ANS" without quotes and send a screenshot of the output.
  • Thank you so much here it is
    Can you try renaming:
    %APPDATA%\Ansys\v202 to v202.old
    %APPDATA%\SpaceClaim to SpaceClaim.old
    %LOCALAPPDATA%\SpaceClaim to SpaceClaim.old
  • I tried it and the same error comes up when I try to open the geometry.
    Can you share a copy of the text from %TEMP%\.ansys\licdebug.SPACECLAIM.202.out ?
  • My temp folder is empty and does not have the .ansys folder to go into.
    Make sure you are looking in %TEMP% and not what you have your temp files directory set to. Anytime you run ANSYS applications it will write a file. It should be C:\Users\username\appdata\local\temp\.ansys
  • 2020/10/14 10:50:46  INFO        Demo license file D:\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic exists.
    2020/10/14 10:50:46  CLIENT_CONNECT                                              3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    2020/10/14 10:50:46  NEW_CONNECTION   Connected to demo server: [email protected]
    2020/10/14 10:50:46  DENIED       a_spaceclaim_dirmod       20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name a_spaceclaim_dirmod does not exist in the licensing pool.
    No such feature exists.
    Feature:    a_spaceclaim_dirmod
    License path: D:\ANSYS Inc\ANSYS Student\Shared Files\Licensing\student.lic;
    FlexNet Licensing error:-5,357
    2020/10/14 10:50:46  DENIED       disc_ess            20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name disc_ess does not exist in the licensing pool.
    Feature:    disc_ess
    2020/10/14 10:50:47  DENIED       disc_sta            20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name disc_sta does not exist in the licensing pool.
    Feature:    disc_sta
    2020/10/14 10:50:47  DENIED       disc_ult            20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name disc_ult does not exist in the licensing pool.
    Feature:    disc_ult
    2020/10/14 10:50:47  DENIED       aa_s_disc            20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name aa_s_disc does not exist in the licensing pool.
    System clock has been set back.
    Feature:    aa_s_disc
    FlexNet Licensing error:-88,309
    2020/10/14 10:50:47  DENIED       DISCOVERY_SPACECLAIM      20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Failover feature 'ANSYS Discovery Live Student' specified in license preferences is not available.
    Feature:    aa_s_disc
    2020/10/14 10:50:47  DENIED       aa_s_aim            20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name aa_s_aim does not exist in the licensing pool.
    Feature:    aa_s_aim
    2020/10/14 10:50:47  DENIED       aa_t_i             20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Request name aa_t_i does not exist in the licensing pool.
    Feature:    aa_t_i
    2020/10/14 10:50:47  DENIED       SPACECLAIM           20.2 (2020.0507)       1/0/0/0         3/3/3/3  3808:SPACECLAIM:Daniel [email protected]:winx64   8068:192.168.1.10
    Failover feature 'ANSYS Academic Teaching Introductory' specified in license preferences is not available.
    Feature:    aa_t_i
    I think this is everything from the last time I tried to run geometry.
    The real problem you are encountering, which is clarified by the log file, is a system clock error.
    Feature:    aa_s_disc
    There are several threads available for this error on the forum, please search for "System clock has been set back" and follow the suggestions.
    Thank you,
    Matt
