Unable to view microplane damage in workbench
Hello everyone, I am trying to view concrete microplane damage using microplane model in ansys workbench R2 2020, But the damage is only available for 1st step of solution, whenever i try to plot other steps, the solution information "Error "The requested MPDP data is not available."" . I am using following commands
/SHOW,PNG
ESEL,ALL
Set,,last
/VIEW,1,1,1,1
PLNSOL,MPDP,TOTA
PLNSOL,MPDP,COMP
PLNSOL,MPDP,TENS
I have also enabled outres,all,all in element command menu.
Kindly help me out.
  • jjdoylejjdoyle PittsburghMember
    I tested your post processing script in MAPDL on simple test input and I am able to extract these results.
    Can you compare your ds.dat file in your WB-Mechanical working directory to the test script below?
    fini
    /clear
    /prep7
    et,1,solid185
    !Material
    E1=36500e6
    v=0.2
    fc = 26e6
    ft = 2.27e6
    !* Material Properties
    mp,ex,1,E1
    mp,nuxy,1,v
    k=fc/ft*1.17
    k0=(k-1)/(2*k*(1-2*v))
    k1=k0
    k2=3/k/(1+v)/(1+v)
    eta = ft/E1
    !Microplane Material Model
    tb,mpla,1,1,6,
    tbdata,1,k0,k1,k2
    tbdata,4,eta,0.96,100
    type,1
    mat,1
    N,1, 0.0, 0.0, 0.0
    N,2, 0.0, 1.0, 0.0
    N,3, 1.0, 0.0, 0.0
    N,4, 1.0, 1.0, 0.0
    N,5, 0.0, 0.0, 1.0
    N,6, 0.0, 1.0, 1.0
    N,7, 1.0, 0.0, 1.0
    N,8, 1.0, 1.0, 1.0
    E,1,5,7,3,2,6,8,4
    nsel,s,loc,x,0
    d,all,ux
    nsel,s,loc,y,0
    d,all,uy
    nsel,s,loc,z,0
    d,all,uz
    allsel
    nsel,s,loc,x,1
    d,all,ux,0.004
    allsel
    fini
    /solu
    antype,0
    autots,on
    nsubst,10,100,10
    outres,all,all
    solve
    fini
    /post1
    set,,last
    PLNSOL,MPDP,TOTA
    PLNSOL,MPDP,COMP
    PLNSOL,MPDP,TENS
  • edited October 21
    @jjdoyle Results can be viewed only for 1st step, if we have multiple steps then the results can't be obtained for 2,3,4...n steps.
    can you also tell me from where did you obtain this relation? "k=fc/ft*1.17"
    I am trying to calibrate a M-25 concrete by kent-park using microplane  model but unable to set the yield strain properly, can you tell me how to calibrate the k0,k1,k2 parameters properly?
