Select one of the 2 volumes
Hi, I want to select one of these volumes (see picture) with coding (Not with picking). I was working with selecting volumes with use of location, but i don't get this one done with use of location. Anyone a clue how this is possible?
Luuk
  • rkumbharrkumbhar PuneForum Coordinator
    Hi @LuukS Do you know the volume number? If yes, you can use the VSEL command. Another approach would be select a keypoint specific to the volume(most probably corner point) using location or number. Then select the volume using commands LSLK, ASLL, VSLA etc.
