Model Check Parameters - MAXRATIO and EPSILON
I am doing certain model checks of my Ansys 2019 R1 setup and I would like to know how can I extract the following ("NASTRAN") parameters:
1) The maximum ratio which represents the ratio between the highest and the lowest term of the stiffness matrix. The value of the model shall be less than 1.0E7. (Modal Analysis)
2) The "EPSILON" value corresponds to the ratio of work done by residual loads vs. work done by external applied loads. The EPSILON ratio computed shall be less than 1.E-8. (Structural Analysis)
Is there a command I can add to extract these ratios?
Thank you!
