New Matrix Feature on ANSYS Maxwell v2020 R1
For the new matrix feature on ANSYS Maxwell v2020 R1, how do you see the combined solution data for multiple reduced matrices? In the 'View Solution' of the created matrix, there is a tab to view the resistance and inductance values of the Matrix. How can I view the combined results for the reduced/grouped matrices, rather than looking at individual reduced/grouped matrices? Thank you.
  • icellb1icellb1 Forum Coordinator
    Hi, @OD_232 ,
    For now it's not able to combined results for reduced matrices under view solution tab. But there might be alternative ways to achieve your goal. For example, in winding window, you can assign number of parallel branches to more than one so you don't have to assign multiple reduced matrices. You can describe more details about your situation here and we'll see if we can help.
  • Thank you for your response. Please what do you mean by winding window?
    Hi, @OD_232 ,
    When you click assign excitation-->add winding, the winding window will pop us that allow you to define the excitation for the winding. On the bottom of the winding window you can type in number of parallel branches.
