Exceeding an internal amplitude limit in the solver.
hi peteroznewman
First of all I simplified my geometry on spaceclaim and created the contact between each shell of the tank and then I applied my loads normally I have a weight force that is applied on the bottom of the tank as well as recesses.
but the calculation doesn't work, I looked at the contact and it is well defined, I don't know what my problem is.
thank you
  • Gary_SGary_S Forum Coordinator
    The message generally means that the model is not constrained.
    Try a simple analysis with fixed supports(s) and gravity to make sure all contacts are working as expected.
