ic engine analysis
veeraveera Member
dear sir
i am simulating the ic engine (diesel -air mixture) with species transport and finite rate
what is the Exponent term while setuping the reaction and protectant ..if i keep everything one i am getting result lesser peak pressure and if i very the exponent term from 1 to 0.5 or different different values that pressure also changes with temperature what is the appropriate value we need to set for corresponding reactant coefficients?
#but my coefficients are correct
