How to export voltage
I was wondering if there is a simple way to export voltage from ANSYS Fluent?
Alex
    If it's a result then one of the File Export options should do it, ASCII tends to be fairly easy to read. What do you want to do with it?
  • I guess figuring our how to get it as a result is the issue then. I know how to export variables, but voltage does not come up as an option for me when I try.
    Alex
  • We were able to find how to look at electric potential (voltage) in Fluent post processing. The issue is the value is zero. We have electric potential turned on and have values for conductivity and magnetic permeability set in our material properties.
    Alex
