How to select only one side of complex geometry using box in Mechanical?
This is a hyoid apparatus from a bat. I need to create a named selection which will require me to select all the faces I have circled in the photo below. However when I use the box select, it selects the faces on the other side of the hyoid body, too. I only want the faces which are facing me in the photo. Hope that makes sense. I started to select each individual faces, but it would take hours. There has to be an easier way! Anyone?
