Ansys RSM tests not working
I just installed Ansys on a new system to make it an Ansys RSM server. This seems not work. In Workbench I can simulate things. But in the RSM Configuration all queues test in errors. The error is rater vague and I don't know where to find the logs. Where can I find these? What could be causing this?
The Report:
RSM Version: 19.1.110.0, Build Date: 4/5/2018 11:06:31 AM
Job Name: Default Test Job
    Type: SERVERTEST
    Client Directory: C:\Users\test_user\AppData\Local\Temp\RsmConfigTest\ggrtsc0j.g0r
    Client Machine: SRV635
    Queue: Default [localhost, default]
    Template: SERVERTEST
Cluster Configuration: localhost [localhost]
    Cluster Type: ARC
    Custom Keyword: blank
    Transfer Option: None
    Staging Directory: blank
    Local Scratch Directory: blank
    Platform: Windows
    Using SSH for inter-node communication on cluster
    Cluster Submit Options: blank
    Normal Inputs: [*,commands.xml,*.in]
    Cancel Inputs: [-]
    Excluded Inputs: [-]
    Normal Outputs: [*]
    Failure Outputs: [-]
    Cancel Outputs: [-]
    Excluded Outputs: [-]
    Inquire Files:
      normal: [*]
      inquire: [*.out]
Submission in progress...
Runtime Settings:
    Job Owner: DASTUD\test_user
    Submit Time: Friday, October 16, 2020 6:16 AM
2.76 KB, .05 sec (58.81 KB/sec)
JobType is: SERVERTEST
Final command platform: AllWindows
RSM_PYTHON_HOME=C:\Program Files\ANSYS Inc\v191\commonfiles\CPython\2_7_13\winx64\Release\python
RSM_HPC_JOBNAME=RSMTest
Distributed mode requested: True
RSM_HPC_DISTRIBUTED=TRUE
Running 5 commands
Job working directory: C:\Users\test_user\AppData\Local\Temp\RsmConfigTest\ggrtsc0j.g0r
Number of CPU requested: 1
AWP_ROOT191=C:\Program Files\ANSYS Inc\v191
Testing writability of working directory...
If you can read this, file was written successfully to working directory
Writability test complete
Checking queue default exists ...
JobId was parsed as: 25
Job was not run on the cluster.  Check the cluster logs and check if the cluster is configured properly.
No files transferred.
  • mrifemrife PHLForum Coordinator
    @lennartm Have you checked the ARC logs? If not their paths are given in the v19.1 Help -> RSM -> RSM Users Guide -> Chapter 11.1 Accessing RSM Log Files (ARC logs listed at bottom of the page). Look for relevant messages in the ARC Node log at the time the test was run.
    Mike
