Continuing calculation from previous module results in WB
I am experimenting with continuing calculation with an updated profile file in workbench. When I duplicate the first module to update the profile and continue with a new one using existing data, it seems that the profile did not actually update (I compared results from previous and after adding new profile in CFD-post). How can I make sure the old profile is removed and the new is in place at the boundary?
Also, is there an easier way to do this than manually? Such as using parameters to set the profile files to automatically update as a parameter in new fluent modules using workbench?
Alex
