Not able to open the ANSYS EDT application
I have been trying to access ANSYS Maxwell on my computer, but I am not able to. So, when I double click on ANSYS EDT shortcut, the program does not boot up. I tried running as an administrator too. It did not help.
So, when I right click and check the file location, it takes me to reg_ansysedt instead of ANSYS EDT application in the C drive.
As it takes me to reg_ansysedt with the prefix reg, I was wondering if it has to do with the registration of my license on this device.
Or if it is the graphics driver on my PC which does not allow me to access Ansys Maxwell? I had to work remotely in the past few months, and the IT team had to make some changes to my PC. So, I am not sure. Any help would be greatly appreciated!
Meanwhile, ANSYS SI wave does boot up!
Best Answers
mmadore Forum Coordinator
@arshiah Please try setting the environment variable ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 to get around the problem.
For guidance on creating an Environment Variable please refer to this link. You need to create a NEW Variable.
New Variable Name: ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL
New Variable Value: 1
Matt
A recent Windows update, Microsoft update KB4571756, results in one of the functions crashing on startup. The variable avoids that.
https://docs.oracle.com/en/database/oracle/r-enterprise/1.5.1/oread/creating-and-modifying-environment-variables-on-windows.html#GUID-DD6F9982-60D5-48F6-8270-A27EC53807D0
Matt
Dear @mmadore This is great! Problem solved. I could boot ANSYS EDT and use it right away. May I know what actually happened?
Great, thanks so much!
I am presently using version 2020/R1 of the Electronics Suite.
I am unable to get EDT and Twin Builder to run on Windows 10 version 20H2 or 2004 machines. Pemag, Pexprt, EMT, Savant, and SIwave run just fine. However, the full Electronics suite works fine on Windows 10 version 1903 or 1909 machines. I have tried the ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL environmental work around as well as changing compatibility mode settings - no luck. Thank you.
Sorry, I still had my comparability mode set for Windows 8 on EDT. Once I removed this, EDT came up fine with the ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL environmental work around. Thanks much.
