APDL Material model in Workbench ?
user8179user8179 GermanyMember
Dear all,
I want to create Drucker prager model (Elasto Plastic) with Density, linear elastic isotrophic and (cohesion,friction angle, flow angle) in workbench but there no such model in engineering data.
after reaserch I get to know about apdl commends in workbench ? and tried to import the DP model from apdl. figure one is defined the variable to replace the existing material property. Figure two, assign the material property to variable (I took the code from apdl).
So my queastion is i am doing it in right way?
please give your suggestions.
Thank you,
kind regards,
naveen maddela
