Need spray cones data
iam trying to simulate ansys cfd ic cold flow engine simulation, i need spray cone data, I have checked the format but unable to understand
"sprayconestime-height: A table that gives information about the spray cone height in millimeters with respect to time in milliseconds."
the above point and how to build the time and height, if you guys have any sample of spray cone data please guide me to the link
thanks
  • jcooperjcooper Forum Coordinator
    edited October 21
    Hi:
    I agree that the reference to "height" is somewhat misleading here.
    However, since the origins and axes of the spray cones in the sample file below are given, I would assume that the remaining time-dependent parameter is the penetration of the spray into the solution domain:
    numberofspraycones,n
    sprayconeaxis,
    x1,y1,z1
    x2,y2,z2
    xn,yn,z
    sprayconestime-height, ( time in seconds and spray penetration in mm)
    t1,h1
    t2,h2
    tl,yl
    The Animate button
    in the IC Engine toolbar, will animate the the spray cone as well as valve and piston movement so that you can see the development of the spray and check your inputs.
    Judy
