The UDF created material does not appear in DPM material selection
MahdiMahdi Member
Hi everyone!
I have a question. I created a new material through a user defined database, and I can select it as a material in "materials" section. However, I am going to use the same material for injection in discrete phase model, and it is not among selectable materials there. Any ideas suggestion? Thank you.
    The fluid materials are different to the particle materials (do NOT ask why!) so check the type is set correctly. You probably need to import a second time with a slightly different data base format.
