Ansys Fluent Setup Failed
Jifweif151Jifweif151 Member
edited October 18 in Ansys Products
As I had the geometry ready and proceeded to the setup stage, somehow I got the following error msg: "This is an educational executable, and can only be used with cases containing less than 512000 cells. Please exit this fluent session and start another session to continue."
I am using the Academic License (with VPN connection to the University network), which should not have this limitation I guess?
Could someone kindly let me know how to resolve this issue?
Thank you so much in advance!!
    It should have picked up the Research licence, can you check it's not already in use?
  • @Rob Hi Rob, I am not quite sure how to check if the Research licence is in use or not, but I did attempt to only open the Setup page and it still didn't work.
  • Can someone please help? This is my undergrad thesis project which will be due soon.
    Thanks!
  • Here is the console:
           Welcome to ANSYS Fluent 2020 R1
           Copyright 1987-2020 ANSYS, Inc. All Rights Reserved.
           Unauthorized use, distribution or duplication is prohibited.
           This product is subject to U.S. laws governing export and re-export.
           For full Legal Notice, see documentation.
    Build Time: Dec 2 2019 14:15:26 EST Build Id: 10114
       This is an academic version of ANSYS FLUENT. Usage of this product
       license is limited to the terms and conditions specified in your ANSYS
       license form, additional terms section.
    Host spawning Node 0 on machine "xxxxxxxx" (win64).
    WARNING: No cached password or password provided.
         use '-pass' or '-cache' to provide password
    Host 0 -- ip 130.179.216.94 -- ranks 0 - 3
     host | 0
      0 : SHM
     Prot - All Intra-node communication is: SHM
    ID  Hostname     Core O.S.     PID  Vendor
    n3  xxxxxxxx 4/8 Windows-x64 2112  Intel(R) Core(TM) i7-7700HQ
    n2  xxxxxxxx 3/8 Windows-x64 11748 Intel(R) Core(TM) i7-7700HQ
    n1  xxxxxxxx 2/8 Windows-x64 11248 Intel(R) Core(TM) i7-7700HQ
    n0*  xxxxxxxx 1/8 Windows-x64 25584 Intel(R) Core(TM) i7-7700HQ
    host xxxxxxxx   Windows-x64 20532 Intel(R) Core(TM) i7-7700HQ
    MPI Option Selected: ibmmpi
    Selected system interconnect: default
    Cleanup script file is C:\Users\xx\Desktop\cleanup-fluent-xxxxxxxx-20532.bat
    > Multicore SMT processors detected. Processor affinity set!
    Reading "C:\Users\xx\Desktop\10% WWR Single_files\dp0\FFF\MECH\FFF.1.msh"...
    Buffering for file scan...
     175547 nodes, binary.
      73036 nodes, binary.
      56384 triangular wall faces, zone 1, binary.
      56492 triangular wall faces, zone 2, binary.
     1219903 triangular interior faces, zone 3, binary.
     1226073 triangular interior faces, zone 4, binary.
      16582 triangular interface faces, zone 9, binary.
      16606 triangular interface faces, zone 10, binary.
     628193 tetrahedral cells, zone 5, binary.
     631311 tetrahedral cells, zone 6, binary.
    Building...
       mesh
    auto partitioning mesh by Metis (fast),
    distributing mesh
    parts....,
    faces....,
    nodes....,
    cells....,
        bandwidth reduction using Reverse Cuthill-McKee: 316167/4316 = 73.2546
    Error at host:  This is an educational executable, and can only be used
  • Geo KarnosGeo Karnos Forum Coordinator
    edited October 22
    Can you try the following:
    In the License preferences as in your first post, change all licenses to 0, except for Academic Research CFD.
    This will only use that license.
    If this does not work, can you please run:
    Start->All Programs->Ansys 2020 R1->Ansys Client Licensing->Client ANSLIC_ADMIN Utility 2020 R1
    When this appears, choose:
    View Status/Diagnostic Options->Display the License status
    Copy all in the window(scrolling up too) and paste it here.
  • Jifweif151Jifweif151 Member
    edited October 22
    Hi, @Geo Karnos
    as for your first suggestion, the console showed "Unexpected license problem; exiting."
    With all the licence disabled except the Academic Research CFD, here is the msg shown when I run the ADMIN utility:
    Oct 22, 2020 11:36: Attempting to display the license status...
    DISPLAY THE LICENSE STATUS:
    ANSYS Licensing Interconnect path = [email protected]
    ANSYS FLEXlm license path = [email protected]
    ***** Note: Due to a FLEXlm limitation, all tasks may not be found *****
    ***** LICENSE SERVER STATUS: [email protected] *****
    lmutil - Copyright (c) 1989-2015 Flexera Software LLC. All Rights Reserved.
    Flexible License Manager status on Thu 10/22/2020 11:36
    [Detecting lmgrd processes...]
    License server status: [email protected]
      License file(s) on vpl-licmgr01.cc.umanitoba.ca: /usr/local/licences/dat/ansys/license.dat:
    vpl-licmgr01.cc.umanitoba.ca: license server UP (MASTER) v11.16.4
    Vendor daemon status (on vpl-licmgr01.cc.umanitoba.ca):
     ansyslmd: UP v11.16.4
    Feature usage info:
    Users of aa_t_a: (Total of 50 licenses issued; Total of 2 licenses in use)
     "aa_t_a" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021
     floating license
      zhoub345 venus.cc.umanitoba.ca venus.cc.umanitoba.ca 16095 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2079), start Sat 10/17 19:25
      Geoff LAPTOP-B27LRB8I LAPTOP-B27LRB8I 14128 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1068), start Thu 10/22 9:26
    Users of aa_r_cfd: (Total of 25 licenses issued; Total of 25 licenses in use)
     "aa_r_cfd" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021
     floating license
      grayg34 cdr2255 cdr2255.int.cedar.computecanada.ca 150133 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 283), start Tue 10/20 0:20
      grayg34 cc08.cc.umanitoba.ca cc08.cc.umanitoba.ca 44682 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 432), start Thu 10/22 10:39
    1 RESERVATION for GROUP BIBEAU_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    6 RESERVATIONs for GROUP BIROUK_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    3 RESERVATIONs for GROUP CLARKS_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    2 RESERVATIONs for GROUP HOLLAE_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    3 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    1 RESERVATION for GROUP MEDEPT_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    3 RESERVATIONs for GROUP MEDEPT_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    Users of aa_r_dy: (Total of 25 licenses issued; Total of 0 licenses in use)
    Users of aa_r_me: (Total of 25 licenses issued; Total of 21 licenses in use)
     "aa_r_me" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021
     floating license
      asgaria me-yl-01.eng.umanitoba.ca me-yl-01.eng.umanitoba.ca 19848 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2141), start Mon 10/5 7:04
      babarinv n177 n177 4084 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1561), start Thu 10/15 18:51
      babarinv n168 n168 6969 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1742), start Thu 10/15 18:51
      babarinv n170 n170 21665 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 742), start Thu 10/15 18:51
      babarinv n153 n153 11161 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 150), start Thu 10/15 18:51
      babarinv n153 n153 11092 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 339), start Thu 10/15 18:51
      babarinv n264 n264 14903 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 561), start Thu 10/15 18:51
      babarinv n294 n294 5754 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2739), start Thu 10/15 18:51
      babarinv n204 n204 20647 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1858), start Fri 10/16 2:08
      babarinv n208 n208 21720 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2388), start Fri 10/16 2:08
      babarinv n204 n204 20652 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1424), start Fri 10/16 2:08
      babarinv n208 n208 21807 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2820), start Fri 10/16 2:08
      babarinv telichev2.eng.umanitoba.ca telichev2.eng.umanitoba.ca 9868 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 3707), start Sat 10/17 8:22
      abedineh ME-OJO-R1.eng.umanitoba.ca ME-OJO-R1.eng.umanitoba.ca 10360 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1180), start Tue 10/20 11:38
      luoy luo1.eng.umanitoba.ca luo1.eng.umanitoba.ca 16248 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2412), start Tue 10/20 21:04
      SAFIANA me-xl-r1.eng.umanitoba.ca me-xl-r1.eng.umanitoba.ca 10352 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1987), start Wed 10/21 13:04
      domingop me-itv-domingo.eng.umanitoba.ca me-itv-domingo.eng.umanitoba.ca 9744 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2909), start Wed 10/21 16:25
      domingop me-itv-domingo.eng.umanitoba.ca me-itv-domingo.eng.umanitoba.ca 260 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 1377), start Wed 10/21 16:39
      domingop telichev2.eng.umanitoba.ca telichev2.eng.umanitoba.ca 9684 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 3412), start Wed 10/21 17:20
      domingop telichev2.eng.umanitoba.ca telichev2.eng.umanitoba.ca 11844 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 3631), start Wed 10/21 17:34
      babarinv me-itv-victor2.eng.umanitoba.ca me-itv-victor2.eng.umanitoba.ca 7660 (v2019.1113) (vpl-licmgr01.cc.umanitoba.ca/1055 2641), start Thu 10/22 11:34
    Users of aa_r_hpc: (Total of 128 licenses issued; Total of 128 licenses in use)
     "aa_r_hpc" v9999.9999, vendor: ansyslmd, expiry: 31-aug-2021
     floating license
      grayg34 cdr2255 cdr2255.int.cedar.computecanada.ca 150133 (v2018.0721) (vpl-licmgr01.cc.umanitoba.ca/1055 1658), start Tue 10/20 0:20, 32 licenses
    20 RESERVATIONs for GROUP BIROUK_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    4 RESERVATIONs for GROUP CLARKS_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    4 RESERVATIONs for GROUP HOLLAE_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    32 RESERVATIONs for GROUP TELICH_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    36 RESERVATIONs for GROUP ORMIST_CFX (vpl-licmgr01.cc.umanitoba.ca/1055)
    Users of aa_mcad: (Total of 125 licenses issued; Total of 0 licenses in use)
    Users of aim_mp1: (Total of 100 licenses issued; Total of 0 licenses in use)
    Users of acfd_vki: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of afsp_gui: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of afsp_optigrid: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of afsp_viewmerical: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of ensight_enterprise: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of envision_pro: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of am_prep: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of granta_sim_mat_data: (Total of 75 licenses issued; Total of 0 licenses in use)
    Users of aa_ds: (Total of 50 licenses issued; Total of 0 licenses in use)
  • @Geo Karnos Thanks a lot for your help!
