meshing failure again
hey i am unable to generate the mesh of a CAD with features.Can someone tell me how to fix it?Pls mesh it in ansys and tell me what operations one need to apply?Pls help.Tahnks in advance.CAD attached
Hello Kumar,
What physics are you trying to solve? Based on your requirement, select appropriate preference (Mechanical, CFD, etc.) as shown below. Then try meshing the model with default mesh settings. If it is a CFD problem, try generating mesh with default settings and curvature sizing function. If the mesh is still failing, please review the geometry either in Design Modeler or SpaceClaim Direct Modeler for any problems and repair the model.
Kumar,
There are numerous resources on youtube (from ANSYS and Channel Partener) that can help you get started:
Advanced Meshing in Workbench
~Sandeep
