MAT_054 Vs. MAT_058
I am hoping someone can discuss the fundamental differences between MAT_054 and MAT_058 composite models.
From what I have seen, MAT_058 describes a composite as nonlinear elastic whereas 54 depicts the composite as linearly elastic.
In regards to MAT 58 being a continuum damage model, and MAT 54 as a progressive ply failure, what is the main difference in these solving approaches?
Any insight is appreciated!
  • cxquancxquan Berkeley, CAForum Coordinator Posts: 79
    What you have summarized are correct. Also MAT_54 can only be applied to composite shell elements while MAT_58 can also be applied to solid elements.
  • rgenestrgenest Member Posts: 20
    First of all, *MAT_054 is the material model used most often to model composite materials because of it simplicity; it is easier to calibrate the material model to experimental data. So, it is usually recommended to start with *MAT_054 and see if you can reproduce your experimental data. If you need a more sophisticated material model, you can use *MAT_058. *MAT_058 can describe the stiffness of composites as linear as well as non-linear. You have more parameters that you can define as a function of strain rate. You also have a choice of failure surfaces. But, this makes *MAT_058 more complex and requires more experimental data. Please refer to the user manual for a description of both material models.
    Also, you can do a 1-element simulation with different loading to see if your material model behaves the way you expect. You can search for "Single-Element Characterization of the LS-DYNA MAT54 Material Model" for more information.
    You can also find more information (scientific papers) on *MAT_054 and *MAT_058 on dynalook.com.
    Let me know how it goes.
    Reno.
