flow rate surface tension
hello
i have a drip tube with water dripping and when i increase the flow rate or frequency of drips they get bigger/more massive.
i see the equation mass x gravity = 3.14(tube diameter)(surface tension)
my mass is changing but not gravity, 3.14 or tube diameter so surface tension must be related to flow rate but I cant find anything online on how to figure this out.
conversely I have a known flow rate and mass and want to determine tube diameter but unsure how to get it as it appears surface tension must be related to flow rate but I dont know how
  • RobRob UKForum Coordinator Posts: 8,395
    edited October 2020
    Surface tension is a material property so is generally constant for a given temperature.
    The above equation is some sort of force balance which would (usually) be solved to find the mass given the other values are generally known.
    I assume the 3.14 is PI to give the tube circumference?
    I don't think you can use that equation for mass flow as the units don't balance.
  • fdnovice7629fdnovice7629 Member Posts: 2
    i have a known flow rate and known mass of the drip and need to determine the diameter of the tube
    A quick google found a Researchgate paper, droplet rate from tube
