Springback Analysis Using Explicit Solver
Implicit analysis is the standard method to solve springback problems. However the convergence using implicit solver is a big concern. In many cases, no converged results could be achieved. I developed an alternative method which uses explicit solver to solve springback problems. I would like to put this as a topic for open discussion. Your comments are highly appreciated. You can check the following link to view the method.
Thanks for sharing.
