Current Excitation in Maxwell
in Electronics
Its a solenoid which I draw on Ansys Maxwell. The coil consists of 100Turns of 23 swg wires. A 10 A current is flow through it.
For current excitation to coil section sheet.
This window pop up
In 'Value' field which value I Should give.
Is it "current" or " Number of turns*Current"(mmf)
10A or 1000A
nchode Forum Coordinator
Since the coil model is solid and a section is used to create the current excitation terminal. You need to provide "Number of turns*Current " as the value for current excitation.
Regards
Navya.
Regards
Navya.
