Analysis Systems Not Showing - 2020R2
I have recently downloaded Ansys Student 2020R2, however I am not able to use any of the tools as the analysis systems tab is not available. I believe this is an issue with the licensing. Please see the image attached. I have already reinstalled with the same issue. I have had Ansys installed previously.
Any help would be greatly appreciated.
  • huwanghuwang Posts: 18Forum Coordinator
    Check and make sure environment variable ANSYSLMD_LICENSE_FILE is set to the ANSYS student license file.
    Also try to rename %APPDATA%\Ansys\v202 folder (e.g. to v202.old).
    Relaunch Workbench 2020 R2 to see how it works.
    If not, zip %TEMP%\.ansys folder and upload the zip file.
