Airfoil CL & CD Start at normal magnitude then skyrocket.
t_topt_top Member
I'm working with a few airfoils, NACA 23012, NACA 63015A, NACA 4412, RC4-10, and Boeing VR-7, analyzing the lift, drag and moment of each.
Currently working on the NACA 63015A. Using velocities(mph) with their respective lift/drag/moment coefficients are below.
  • 25mph {-0.900/0.0257/0.0225}
  • 50 {-3.7196/0.881/0.0856}
  • 75 {-8.507/0.182/0.1837}
  • 100 {-15.368/0.30669/0.3003}
  • 125 {-24.249/0.4598/0.444}
  • 140 {-21.468/1.4205/0.8104}
  • 150 N/A
After 25mph both lift and drag are too high. I recently changed to reference values to get the 25mph to be in its normal range.
Airfoils' length are 8.9in = .22606m
Here are the details for the 2D case:
Solver:
Pressure-Based
Steady state
Velocity formulation -> Absolute
Model:
Viscous Model -> Spalart-Allmaras (1eqn)
Vorticity-Based
Fluid:
Air
Density = 1.225 (kg/m^3)
Viscosity = 1.802e-5 (Kg/m-s)
Reference Values changes:
Area = 0.22606
Density = 1.225
Depth = 1
enthalpy = 0
Length = 0.22606
Pressure = 0
Temperature= 288.16
Velocity = varies
Ratio of specific heat = 1.4
Yplus for heat tran. coef. = 300
Turbulence
Specification Method -> Turbulent Viscosity Ratio
Ratio = 10
Outlet pressure = 0
Solution Method
Coupled
Gradient -> Least Squares Cell Based
Pressure->Second Order
Momentum -> Second Order Upwind
Modified Turbulent Viscosity -> Second Order Upwind
Pseudo Transient ->off
Solution Controls:
Flow Courant Number = 200 (recently reduced it to 1 after reading up on it.)
Momentum = .5
Pressure = .5
Relaxation factors
Density, Body Force, Turbulent viscosity = 1
Body Forces = .8
Report definitions of drag
x=cos(angle)
y=sin(angle)
Report definitions of lift
x=-sin(angle)
y=cos(angle)
Report definitions of moment
Center
x=1/4 of span
y= location of x in y direction.
ONE LAST THING
The contour graphics are showing the boundaries of the elements instead of a filled in contoured graph.
More pictures are below that may be relevant
