Could not access to license server.
redantredant Member Posts: 15
Dear Sir,
I could not start Electomagnetics desktop 2020R2.4
My computer should connect to license server through VPN
It writes "Failover feature 'ANSYS electronics_desktop' specified in license preferences is not available. FLEXlm server is not responding. Resource temporarily not available."
Here is ansysedt.exe.202.out file
2020/10/29 22:19:29   INFO               Starting Licensing Client Proxy server.
2020/10/29 22:19:29   INFO               C:\Program Files\AnsysEM\AnsysEM20.2\Win64\licensingclient\winx64\ansyscl.exe -acl 19492.21599 -nodaemon -log C:\Users\ant.lukyanov\AppData\Local\Temp\.ansys\ansyscl.ant-lukyanov.log
2020/10/29 22:19:29   INFO               Started ANSYSLI server.
2020/10/29 22:19:31   CLIENT_CONNECT        1/1/1/1  19492:ANSYSEDT.EXE:[email protected]:winx64  8388:192.168.0.25
2020/10/29 22:19:31   NEW_CONNECTION     Connected to Licensing Client Proxy server: [email protected]
2020/10/29 22:22:46   INFO               Unable to connect to FLEXlm path [email protected]; adding to "Unavailable FLEXlm Servers" cache.
2020/10/29 22:22:46   DENIED             designer_desktop               20.2 (2020.0507)            1/0/0/0                1/1/1/1  19492:ANSYSEDT.EXE:[email protected]:winx64  8388:192.168.0.25
      Failover feature 'Designer/NEXXIM Desktop' specified in license preferences is not available.
         ANSYSLI_SERVERS: [email protected]
         FLEXlm Servers: [email protected];[email protected];[email protected]
How to solve problem?
Thank you
  • redantredant Member Posts: 15
    Just found that the problem comes from win 10 updates starting from 1909 or comes from KB4571756 that included in next win updates (1909, 2004 and 20H2)
    A license server located on another machine. I have access to this machine through the VPN channel. The ports 1055 and 2325 are opened.
    The Electronics Desktop 2020 R2.4 cannot find the license server still.
    ANSYS_EM_DONOT_PRELOAD_3DDRIVER_DLL=1 solves problem of installation, but not license server connection
    The license server writes:
    2020/11/03 21:38:23   Request being processed: Retrieve Current License Manager Run Mode
    2020/11/03 21:38:23   getIniOptionLMRunMode
    2020/11/03 21:38:23   _________________________________________________________________________________________________
    2020/11/03 21:38:23   Request being processed: Retrieve License File List
    2020/11/03 21:38:23   getLicFileList
    2020/11/03 21:38:23   Request being processed: View FlexNet Licenses
    2020/11/03 21:38:23   viewFlexNetFile                 LicFile='ansoftd.lic'
    2020/11/03 21:38:30   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:38:30   viewansysliLog
    2020/11/03 21:38:30   _________________________________________________________________________________________________
    020/11/03 21:40:55   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:40:55   viewansysliLog
    2020/11/03 21:40:56   _________________________________________________________________________________________________
    2020/11/03 21:41:00   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:41:00   viewansysliLog
    2020/11/03 21:41:01   _________________________________________________________________________________________________
    2020/11/03 21:41:08   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:41:08   viewansysliLog
    2020/11/03 21:41:09   _________________________________________________________________________________________________
    2020/11/03 21:41:13   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:41:13   viewansysliLog
    2020/11/03 21:41:13   _________________________________________________________________________________________________
    2020/11/03 21:41:20   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:41:20   viewansysliLog
    2020/11/03 21:41:20   _________________________________________________________________________________________________
    2020/11/03 21:41:26   Request being processed: Retrieve Current License Manager Run Mode
    2020/11/03 21:41:26   getIniOptionLMRunMode
    2020/11/03 21:41:26   _________________________________________________________________________________________________
    2020/11/03 21:41:26   Request being processed: View FlexNet Debug Log
    2020/11/03 21:41:26   viewLicenseLog
    2020/11/03 21:42:43   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:42:43   viewansysliLog
    2020/11/03 21:42:44   _________________________________________________________________________________________________
    2020/11/03 21:42:47   Request being processed: View Licensing Interconnect Log
    2020/11/03 21:42:47   viewansysliLog
    2020/11/03 21:42:47   _________________________________________________________________________________________________
    2020/11/03 21:42:57   Request being processed: Retrieve Current License Manager Run Mode
    2020/11/03 21:42:57   getIniOptionLMRunMode
    2020/11/03 21:42:57   _________________________________________________________________________________________________
    2020/11/03 21:42:57   Request being processed: View FlexNet Debug Log
    2020/11/03 21:42:57   viewLicenseLog
    Just found  that I need to start the Electomagnetics desktop 2020R2.4 with Administrative rights!
    Solved
  • akhemkaakhemka Forum Coordinator Posts: 676
    Hi @redant ,
    You already found an answer to this question. I will mark it resolved.
    Ashish Khemka
    Another issue was with ansyslmd.lic file
    It had first three lines:
    SERVER Nemo ............ 1055
    VENDOR ansyslmd PORT=2325
    USE_SERVER
    # Products licensed in this file:
    The first line is ok.
    The second line need to fix ansyslmd.exe on port 2325. It was need because I using VPN channel and have only one opened port 2325 in firewall. Other ports was to open difficult.
    And third line gives that ansyslmd.exe did not load on port 2325 every time when I reload license manager.
    I deleted this third line and all works fine.
    BR
    Anton
