node of a element
ThePhontyfexThePhontyfex Member
edited October 31 in Preprocessing
Hi guys!
I have a question:
I select node from 'select mesh by ID-> nodes-> 1- (all) and I create a named selection. When i export It in excel the row does not match the node (if you do not consider the First line). For example the line 176 does not match to node 176 but matched to node 2871. I want the nodes to be consecutive.Is there a way to do It?
