Interpolation methods in ANSYS Mechanical
Hello all,
I am in the process of modelling a full 3D tyre but have found that my model might be undergoing volumetric locking. I have read that by reducing the interpolation method that the effect that volumetric locking has on ones results can reduce. In my results the excessive non-realistic stiffness in the figure below, I believe, illustrates this phenomenon.
I am using ANSYS Mechanical, and saw that at the interpolation method my simulation is using; Mechanical APDL.
I have read this discussion https://forum.ansys.com/discussion/4342/interpolation-methods, but am unsure how to change the interpolation method as the box does not have a drop down option (see image above).
The following are my Analysis Settings:
Thank you in advance
mrife PHLForum Coordinator
Hi @kirstenbraun
Workbench Mechanical will change the element integration (full, reduced) based on the material assigned to the part. For incompressible, or nearly so, a reduced scheme will be used. You can manually set this by first selecting the Geometry object; then in Details: Definition -> Element Control set this to Manual. Now select the specific part and in its Details: Definition -> Brick Integration Scheme can be manually set.
Mike
Hi @kirstenbraun ,
The interpolation method post you entered here is for Fluent and you are looking to fit a force-displacement data? Please comment.
Ashish Khemka
Hello @akhemka,
That is correct, the link I posted is for Fluent and even though I am looking at ANSYS Mechanical I thought I’d just mention it to emphasize that I couldn’t find any information on interpolation methods in ANSYS Mechanical.
The data that I am looking at is Vertical Force versus Vertical Displacement, and am hoping to change the interpolation method so that the effect of volumetric locking (which I suspect to be the cause of the non-realistic stiffness increase in my result figure previously attached) is decreased.
Thank you
Kirsten
Hi @kirstenbraun
Mike
