How do I mesh a fluid flow around a solid?
Hey everyone,
Firstly, I'd like to thank anyone that takes their time out to help me. I really appreciate the help. Thank you.
Now, on to my question. I'm new to Ansys and I'm looking at studying the wind loads on a solar panel located on a pitched roof. I've constructed my fluid domain and my solid body. The solids are - One main body (house), 3 solar panels (3 seperate solid bodies) attached to main body. (Seperate question: Do i need to define anything like contact between the house and solar panels or is it done automatically before meshing?) . My main question is : How do I mesh this? Should I suppress the solid or mesh the solid or just the surface of the solid? I know i have to mesh my fluid domain obviously. I've been getting errors while meshing so I just wanted to figure out what I've been doing wrong. I'll attach a screenshot that should hopefully give a better idea of my model.
If i have to mesh both solid and fluid domain, how do I resolve any errors while meshing? Shared topology? I'm clueless right now.
Thanks. :)
First subtract solid bodies from fluid body.
Then create one component for all bodies.
Use Share Topology option so that mesh is connected between solids and fluid.
For meshing, you will need to give different sizing to different faces, bodies or edges.
Please check
Please see help manual for more details about these commands.
Please search through forum where you can find lot many posts on meshing sizes.
Keyur
So does this mean that I have to suppress the solid body for meshing and only mesh the fluid domain with a boolean subtract?
You will need to perform the Boolean subtract first and then suppress all the solid parts. This way, you will only be left with the fluid geometry.
Thanks.
